[gdal-dev] (no subject)
Even Rouault even.rouault at mines-paris.org
Thu Dec 10 06:34:22 EST 2009
Roger,
this is weird indeed as I use daily MSYS on trunk... I'd bet that you have  an
installed version of cpl_string.h in /usr/local/include that corresponds to the
1.6.3 version that didn't have the CPLIsUTF8 and CPLForceToASCII symbols. If
you've done a make install when building 1.6.3 before, it would have gone there.
And as -I/usr/local/include is before -I/home/s1155/gdal_svn/gdal/port on the
GCC command line, the old version would be picked up. I'd recommand you to use
--prefix when you configure to be able easily to switch between different
versions to avoid installing stuff in "system" directories.
Best regards,
Even
