[Gdal-dev] gdal build failure on SUSE LINUX Enterprise Server 10
Alans alan.stratford at goodrich.com
Fri Dec 11 12:18:10 EST 2009
pcreso wrote:
> Hi Alan,
> This doesn't fix you problem specifically, but may help.
> We usually use the packages from the OpenSuse Geo repository, which has
> SLES specific builds available. (We are using SLES for most Linux servers
> in our organisation)
> See:  http://download.opensuse.org/repositories/Application:/Geo/SLE_10/
> This saves either compiling from source or building our own SLES packages.
> If we need something, like a new version which is not there, I have found
> the repository maintainers are very responsive to requests to provide
> updates & new packages.
> While I like OpenSuse anyway, as a FOSS GIS "specialist" the Geo
> repository is the main reason I primarily use OpenSuse as a Linux distro.
> Cheers,
>   Brent Wood
Thanks Brent,
I did get the rpm for gdal 1.6.3 to install, but I need support for the SRP
format, which is only present in the latest daily builds.
Regards
Alan
View this message in context: http://n2.nabble.com/gdal-build-failure-on-SUSE-LINUX-Enterprise-Server-10-tp4145777p4152485.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
