[gdal-dev] RasterIO slower on Windows
Adam Kubach adamkubach at gmail.com
Sat Dec 12 00:14:51 EST 2009
Even,
Yes, this is on the same machine.  The driver is GeoTIFF (I haven't
tried other ones) with external overviews.
Adam
On Fri, Dec 11, 2009 at 12:41 PM, Even Rouault
<even.rouault at mines-paris.org> wrote:
> Adam,
> I assume that you're testing on the same machine. Such difference is not
> expected. Do you see that slowdown with different GDAL drivers or just for
> one in particular (which one?)
> Windows builds are able to use overviews. But are you speaking about
> internal GeoTIFF overviews or about external overviews (.ovr files) ?
> Even
> Adam Kubach a écrit :
>> Hi,
>> It appears that my calls to RasterIO are about 10 times slower on
>> Windows than Linux when reading from the same dataset.  I wouldn't
>> think that there would be a noticeable difference.  Has anyone else
>> seen this?  Is it possible that the overviews aren't being used on
>> Windows?  Is there anyway I can verify that they are being used (Other
>> than a debugger)?
>> Thanks,
>> Adam
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
