[gdal-dev] How to set BoundingBox within a shapefile using OGR Pythons bindings
Daniele Romagnoli daniele.romagnoli at geo-solutions.it
Thu Dec 17 03:23:19 EST 2009
Thank you guys for the correction.
It seems I have copied an old polygon definition in my previous email (in my
last script, I have changed odd ',' with ' ' to set couples). The issue was
that I missed double brackets. However, the importFromWkt didn't work (Being
undefined in the python bindings, I guess).
Before sending the email, I had tried ogr.CreateGeometryFromWkt(wkt) as
suggested by Even, but having missformed WKT (single brackets), it gave me
ERROR 5: OGR Error: Corrupt data. Now my problem have been solved. Thank you
all.
Best Regards,
Daniele
On Wed, Dec 16, 2009 at 7:43 PM, Frank Warmerdam <warmerdam at pobox.com>wrote:
> Daniele Romagnoli wrote:
>> Hi list,
>> I'm creating a shapefile using the OGR python bindings. (from  the 1.6.1
>> installer)
>> I have some issues in creating the boundingBox for it.
>> This is a snippet of the code I'm using:
>> from osgeo import ogr
>> from osgeo import osr
>> northings_llc = dd['northings_llc']
>> northings_urc = dd['northings_urc']
>> eastings_llc = dd['eastings_llc']
>> eastings_urc = dd['eastings_urc']
>> t_srs = osr.SpatialReference()
>> t_srs.SetFromUserInput('EPSG:32632')
>> drv = ogr.GetDriverByName('ESRI Shapefile')
>> ds = drv.CreateDataSource(fileout)
>> x0, y0, x1, y1 = str(eastings_llc[0][0]), str(northings_llc[0][0]),
>> str(eastings_urc[0][0]), str(northings_urc[0][0])
>> layer = ds.CreateLayer(ds.GetName(), geom_type = ogr.wkbPolygon, srs =
>> t_srs)
>> geom = ogr.Geometry(type = layer.GetLayerDefn().GetGeomType())
>> geom.AssignSpatialReference(t_srs)
>> wkt = 'POLYGON('+x0+','+y0+','+ x0+','+ y1+','+ x1+',' +y1+','+ x1+','
>> +y0+','+ x0+',' +y0+')'
> Daniele,
> You are not formatting your WKT right. There should be spaces between
> x and y.  The commas are only between tuples.
> eg.
> POLYGON ((479819.84375 4765180.5,479690.1875 4765259.5,...
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam<http://pobox.com/%7Ewarmerdam>
> and watch the world go round - Rush    | Geospatial Programmer for Rent
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Eng. Daniele Romagnoli
Software Engineer
GeoSolutions S.A.S.
Via Carignoni 51
55041 Camaiore (LU)
Italy
phone: +39 0584983027
fax:     +39 0584983027
mob:   +39 328 0559267
http://www.geo-solutions.it
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20091217/dcd6be0c/attachment.html
