[gdal-dev] Hangs on OGRLayer ResetReading
Matthew Denno mgdenno at gmail.com
Sat Dec 19 13:53:42 EST 2009
I was wondering if someone could help me out.  I have been working on
a little piece of code here and seems to be stuck.  The piece is very
close to one of the examples on the website so I would think that it
would be right...maybe I have missed something simple.  Anyway below
is the code.  It seems like it hangs on "poLayer->ResetReading();".
It successfully prints out the number of features then dies.
Thanks,
Matt
CODE:
int z_shape_to_delaunay(Delaunay &dt,
                        QString myLayerPath,
                        bool useAnalysisMask,
                        QString analysisMaskPath)
    qDebug("z_shape_to_delaunay");
    OGRRegisterAll();
    OGRDataSource       *poDS;
    poDS = OGRSFDriverRegistrar::Open( myLayerPath, FALSE );
    if( poDS == NULL )
        qDebug( "Shapefile failed to open" );
        exit( 1 );
    OGRLayer  *poLayer;
    poLayer = poDS->GetLayer( 0 );
    qDebug() << "Number of Features: " << poLayer->GetFeatureCount(1);
    if (poLayer = NULL)
        qDebug( "Layer ID was out of range" );
        exit( 1 );
    OGRFeature *poFeature;
    qDebug("start loop");
    while( (poFeature = poLayer->GetNextFeature()) != NULL )
        OGRGeometry *poGeometry;
        poGeometry = poFeature->GetGeometryRef();
        qDebug("in loop");
        if (!poGeometry)
            continue;
        if( poGeometry != NULL && poGeometry->getGeometryType() == wkbPoint25D )
            OGRPoint *poPoint = (OGRPoint *) poGeometry;
            Point pt = Point(poPoint->getX(), poPoint->getY(), poPoint->getZ());
            dt.insert(pt);
        else
            qDebug( "no point geometry" );
    return (0);
