[Gdal-dev] Which tool to add an offset?
NopMap ekkehart at gmx.de
Tue Dec 22 11:12:49 EST 2009
Hi!
I am building a map with several layers containing OSM geometry and
hillshading+contours. The rendering chain for the hillshading is
SRTM GeoTiff -> gdal_merge -> gdal_warp -> hillshading.exe -> mapnik
Now I have the problem that the hillshading and the geometry do not
quite match. It seems the hillshading is offset some constant distance
to the north and west. I suspect as the offset looks like some 100m that
this is a result of the sample size of the SRTM data and the particular
hillshading algorithm.
Now I am looking for a way to correct this offset, so that optically the
shading rests in the expected position relative to the geometry. But I don't
know how to do this. I have tried modifying the projections for gdal_warp
with some false northing, but the results always remains the same.
Any idea on how to move the hillshading 100m to the south?
thank you
    Nop
View this message in context: http://n2.nabble.com/Which-tool-to-add-an-offset-tp4204322p4204322.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
