[gdal-dev] python gdal problem
Leonardo Hardtke leohardtke at gmail.com
Tue Dec 29 09:29:21 EST 2009
Hi all,
I've been using Python-gdal bindings in Ubuntu 9.04 without problems.
Recently I made a fresh Ubuntu 9.10 install and I can't install the bindings
on it...
leo at rs7 ~/Descargas/GDAL-1.6.1 $ python setup.py build
numpy include /usr/lib/python2.6/dist-packages/numpy/core/include
setup.py:78: DeprecationWarning: The popen2 module is deprecated.  Use the
subprocess module.
  import popen2
running build
running build_py
creating build
creating build/lib.linux-x86_64-2.6
copying gdal.py -> build/lib.linux-x86_64-2.6
copying ogr.py -> build/lib.linux-x86_64-2.6
copying osr.py -> build/lib.linux-x86_64-2.6
copying gdalconst.py -> build/lib.linux-x86_64-2.6
copying gdalnumeric.py -> build/lib.linux-x86_64-2.6
creating build/lib.linux-x86_64-2.6/osgeo
copying osgeo/gdal.py -> build/lib.linux-x86_64-2.6/osgeo
copying osgeo/osr.py -> build/lib.linux-x86_64-2.6/osgeo
copying osgeo/gdal_array.py -> build/lib.linux-x86_64-2.6/osgeo
copying osgeo/gdalconst.py -> build/lib.linux-x86_64-2.6/osgeo
copying osgeo/__init__.py -> build/lib.linux-x86_64-2.6/osgeo
copying osgeo/gdalnumeric.py -> build/lib.linux-x86_64-2.6/osgeo
copying osgeo/ogr.py -> build/lib.linux-x86_64-2.6/osgeo
running build_ext
Could not run gdal-config!!!!
building 'osgeo._gdal' extension
creating build/temp.linux-x86_64-2.6
creating build/temp.linux-x86_64-2.6/extensions
gcc -pthread -fno-strict-aliasing -DNDEBUG -g -fwrapv -O2 -Wall
-Wstrict-prototypes -fPIC -I../../port -I../../gcore -I../../alg
-I../../ogr/ -I/usr/include/python2.6
-I/usr/lib/python2.6/dist-packages/numpy/core/include -c
extensions/gdal_wrap.cpp -o
build/temp.linux-x86_64-2.6/extensions/gdal_wrap.o
cc1plus: warning: command line option "-Wstrict-prototypes" is valid for
Ada/C/ObjC but not for C++
extensions/gdal_wrap.cpp:129:20: error: Python.h: No existe el fichero ó
directorio
extensions/gdal_wrap.cpp:2502:4: error: #error "This python version requires
swig to be run with the '-classic' option"
extensions/gdal_wrap.cpp:2587:22: error: cpl_port.h: No existe el fichero ó
directorio
extensions/gdal_wrap.cpp:2588:24: error: cpl_string.h: No existe el fichero
ó directorio
extensions/gdal_wrap.cpp:2590:18: error: gdal.h: No existe el fichero ó
directorio
extensions/gdal_wrap.cpp:2591:23: error: gdal_priv.h: No existe el fichero ó
directorio
extensions/gdal_wrap.cpp:2592:22: error: gdal_alg.h: No existe el fichero ó
directorio
extensions/gdal_wrap.cpp:2593:24: error: gdalwarper.h: No existe el fichero
ó directorio
extensions/gdal_wrap.cpp:734: error: expected initializer before ‘*’ token
extensions/gdal_wrap.cpp:789: error: expected initializer before ‘*’ token
extensions/gdal_wrap.cpp:810: error: expected initializer before ‘*’ token
In file included from /usr/include/c++/4.4/stdexcept:38,
                 from extensions/gdal_wrap.cpp:2521:
/usr/include/c++/4.4/exception:35: error: expected declaration before end of
line
error: command 'gcc' failed with exit status 1
the problem is with gdal-config (it is installed on /usr/local/bin), but I
don't now how to fix it!
Tanks in advise
Lic. Leonardo A. Hardtke
Laboratorio de Teledetección y S.I.G.
Centro Nacional Patagónico (CONICET)
Bvd. Brown 2825, 9120
Puerto Madryn, Chubut, Argentina
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20091229/bed5a68d/attachment.html
