[gdal-dev] -update -append -f kml and -sql options for time series?
Christopher Condit condit at sdsc.edu
Mon Feb 2 14:01:23 EST 2009
Hi Jeff-
> I have no idea where to send this and after signing up for the another
> list server, I thought I might try here. Let me first say that I have
> been using the heck out of gdal, ogr2ogr, and postgis for a few days
> now to generate kml files with relative ease, using commands like:
> ogr2ogr -f kml himom.kml PG:"host=localhost dbname=$1" -sql "select
> st_transform(boundary,4326), blah, blah, blah from my table"
> While this is awsome, I need to export a timestamp/timespan into the
> kml file as well so I can make use of the time slider in google earth.
> I'm a relative newbie to xml/kml and had no idea if ogr2ogr/postgis
can
> do this. I'm pretty sure after some experimentation, that
concatenating
> multiple files:
> st_transform(boundary,4326), blah, blah, blah from my table where time
> = this_time"
> ogr2ogr -update -append -f kml himom.kml PG:"host=localhost dbname=$1"
> -sql "select
> = next_time"
> seems to only produce a file with the last query. So my questions are
> these:
> 1) is it possible to include additional tags
> <TimeSpan><when>...</when></TimeSpan> as part of the sql query (e.g.
> next_time as TimeStamp),
At this point the KML driver does not recognize the Date/Time type in
OGR. Your idea is a good one, but since the output of the transformation
is KML the driver should be escaping the content of the elements. So
your content would end up like:
&lt;TimeSpanA&gt; and so forth. See point 4 below for a possible
solution.
> 2) Does anyone know if the -update -append works with -sql,
It's not that it doesn't work with -sql, it's that the current KML
driver doesn't support an update.
> 3) While I think I can hack a solution (read I must hack a solution),
> where is the documentation for adding features to ogr2ogr),
http://www.gdal.org/ogr/ogr_drivertut.html
is a good place to start. The existing driver is limited in its
capabilities. I'm in the process of updating the driver to work with
libkml, at which point updates and appends would be supported.
> 4) Would it be easier to post process the generated kml file(s) and
> manipulate the file/entries myself  using another tool since I'm kind
> of new to xml/kml/gdal/etc.
Yes. I think the easiest way is to simply write a short XSL transform
that you can filter your content through. You can use this to both
combine your various KML outputs and change the dates (which come out as
strings) to actual time stamps.
I wrote something on the wiki about applying styles, but you could
easily adapt this to whatever you need.
http://trac.osgeo.org/gdal/wiki/KML
-Chris
Christopher Condit
condit at sdsc.edu
(858) 822-5483
