[gdal-dev] core dumping on PNG RGB creation
Jared Rubin JARED.RUBIN at saic.com
Mon Feb 2 15:13:22 EST 2009
But if the following define is set when building gdal
-DSUPPORT_CREATE then the PNG driver will support the CREATE method
Jared
On Mon, 2009-02-02 at 20:05 +0000, Lucena, Ivan wrote:
> That is because the PNG driver
