[Fwd: Re: [gdal-dev] Warping an already georeferenced image with control points
Jan Hartmann j.l.h.hartmann at uva.nl
Sat Feb 7 15:10:36 EST 2009
No, this doesn't seem to work. Although the coordinate system *is*
retained when I add -a_srs to the gcps, the boundaries of the input file
are discarded: they are reset to the pixel dimensions of the file. Is
this a bug?
Jan
Frank Warmerdam wrote:
> Jan Hartmann wrote:
>> Hi,
>> I am trying to georeference old maps in two steps: first
>> georeferencing them from the old projection to a modern one, and then
>> ameliorating the georeferenced image by rubber-sheeting it on the
>> base of control points, mostly triangulation points for which the
>> coordinates in the old and new maps are known.
>> The second step causes trouble: if I add  control points to the
>> georeferenced image with gdal_translate -gcp , the projection
>> information gets lost.
>> Yet, AFAICS it should be possible: if I use gdaltransform -s_srs
>> EPSG:28992 -t_srs EPSG:28992 -gcp ... , I can use control points with
>> coordinates in EPSG:28992 and get a correct transformation.
>> So: regarding this behavior  of gdal_translate, to discard projection
>> information when control points are added: is it a bug or is it the
>> expected behavior? In the last case, how can I rubber-sheet an
>> already georeferenced map?
> Jan,
> If you use the -a_srs switch of gdal_translate in combination with the
> -gcp switch to add gcps, the GCPs should be recorded as being in the
> coordinate system described by -a_srs.  Because there is no reason to
> believe that the current image coordinate system is related to the
> coordinate system of the GCPs, no effort is made to use the existing
> image
> coordinate system as the default GCP coordinate system.
> By the way, setting GCPs with a GCP coordinate system on an image is
> likely
> to not work with most GDAL supported formats, and the coordinate system
> related aspect may also be supported in a variable fashion depending
> on the
> format driver's implementation.
> Hopefully things work well with the GeoTIFF format, which I assume you
> have
> been using.
> Best regards,
