[gdal-dev] concerning VSIInstallSubFileHandler
Mon Feb 9 15:21:04 EST 2009
Dan Greve wrote:
> Greetings,
> I am currently accessing datasets which are embedded inside a single
> file.  Each dataset is a given file offset and length inside of the
> larger file.
> I saw in the latest doxy-docs here
> <http://www.gdal.org/ogr/cpl__vsi_8h.html> that there is a
> VSIInstallSubFileHandler for doing just that, and look forward to
> testing it out.  My concern with it, as well as the normal
> VSIMemFileHandler, is in accessing large files.  I have 2 GB images,
> embedded within files that are up to 100 GB in size.  Does the
> VSIMemFileHandler do any sort of paging so that the entire source image
> is not read into memory?
Dan,
The VSIMemFileHandler treats a memory buffer as a file.  There is no support
in it for paging from a file so it is only suitable when you are prepared
to load the object into RAM.
The VSISubFileHandler on the other hand just manages access to a file through
regular file access handle, but keeping track of an offset to the sub file.
So it does not use appreciably more memory than a normal file access.
I believe the subfilehandler would be the suitable tool for you.  I believe it
is only available in GDAL trunk, not 1.6.x.
Best regards,
