[gdal-dev] Open source GIS cataloging software?
Even Rouault even.rouault at mines-paris.org
Wed Feb 11 17:22:10 EST 2009
Jonathan,
Provided that you have some basic scripting/coding abilities, GDAL/OGR would
certainly be able to solve your need. Python might be a good choice, as you
can use the GDAL/OGR bindings. Or just use the C API.
For retrieving the boundings boxes:
Key API for raster part : gdal.Open(), Dataset.GetGeoTransform()
Key API for vector part : ogr.Open(), DataSource.GetLayer(), Layer.GetExtent()
OGR can also be used to create the output file.
The tutorials on gdal.org and gdal.org/ogr should be good starting points.
Le Wednesday 11 February 2009 22:50:18 Jonathan Greenberg, vous avez écrit :
> Sorry for the cross-posting.  I was wondering if anyone has a unix
> (preferably) or windows program that can spider a directory, recursively
> searching for raster and vector data, and create bounding box polygons for
> each raster/vector it finds, with attributes indicating the path-to-file.
