[Gdal-dev] GDAL - CSharp
Tri rsosnowski at cableone.net
Wed Feb 11 18:21:26 EST 2009
Tamas,
I'm creating web services.  This is first go on 64 bit machine - plenty of
32 bit web services to fall back on.  The problem is I was using FDO which
as far as I know has only 32 bit compiled code.  So I set the 'Enable 32 Bit
Application' to true, published the application, then tried to run from
localhost.  There were no problems with 64 bit, 32 bit conflicts this way.
However, I then started getting an error that says:
System.IO file not found.   I'm not using System.IO file in the web service.
So, I thought I would use your compiled 64 bit GDAL / OGR code to create a
new web service, but running into previously mentioned problem taking this
approach.
Thanks again.....
Tamas Szekeres wrote:
> What kind of application you develop  Console/WinForms/ASP.NET ?
> Wouldn't it be sufficient to use 32 bit binaries and compile your app with
> the /platform:x86 option?
> Best regards,
> Tamas
> 2009/2/12 Tri <rsosnowski at cableone.net>
>> Hi Tamas and others - thanks for the help.
>> By application executing directory - I've copied the files to both the
>> bin
>> directory under the project and the obj, Debug directory under the
>> project.
>> When I run the application in debug mode, the same problem occurs:
>> System.TypeInitializationException:   The type initializer for
>> OSGeo.OGR.Ogr
>> threw an exception
>> InnerException:   The type initializer for OSGeo.OGR.OgrPINVOKE threw an
>> excpetion
>> I am using the 64 bit compiled code from you on Vista 64 bit machine.
>> Any more ideas?  Thanks.....
>> > Hi,
>> > You might have to copy all of the dll-s (*_csharp.dll, *_wrap.dll,
>> > gdal16.dll, proj.dll etc.) to the application executing directory.
>> > Best regards,
>> > Tamas
>> > 2009/2/11 Tri <rsosnowski at cableone.net>
>> >> Can't get GDAL / OGR to work with CSharp.  Using the CSharp dlls, I
>> keep
>> >> getting exceptions like:
>> >> OgrPINVOKE, threw an exception.
>> >> TO TRY TO GET TO WORK I DID:
>> >> - Copied the csharp dlls into project,
>> >> - Created a reference to the dlls.
>> >> What am I doing wrong?
>> >> View this message in context:
>> >> http://n2.nabble.com/GDAL---CSharp-tp2308674p2308674.html
>> >> Sent from the GDAL - Dev mailing list archive at Nabble.com.
>> >> _______________________________________________
>> >> gdal-dev mailing list
>> >> gdal-dev at lists.osgeo.org
>> >> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>> http://n2.nabble.com/GDAL---CSharp-tp2308674p2312047.html
View this message in context: http://n2.nabble.com/GDAL---CSharp-tp2308674p2312090.html
