[gdal-dev] Generating GML from Database - Problem: No decimal values
Thu Feb 12 12:04:23 EST 2009
Gregor Fikoczek wrote:
> Hi list,
> i got a problem by generating a GML-File from the Oracle- and MySQL-DB using
> ogr2ogr, so I alway getting in MySQL/oracle instead of a float-value an
> rounded integer-value (mostly 0) without any decimal numbers.
> So is there any option i got to set or a workaround for that problem,
> aspacialy in oracle?
Gregor,
If you can file a ticket with details on how to create a minimal test table
in mysql and/or oracle I'll have someone look at it.
Best regards,
