[gdal-dev] ARM platform compatibility
Tom Kazimiers 2voodoo at gmx.de
Mon Feb 16 21:05:03 EST 2009
Hi Adriano,
which version of CGAL did you compile for ARM?
I use 1.5.2 and reading shapefiles works very well.
Regards,
Tom
Adriano C Naspolini schrieb:
> Hi,
> I developed an application and it runs perfectly over X86. However,
> when i try to run it on ARM it stops reading shapefiles (actually it
> reads wrong coordinates). I wrote a simple program to tell just the
> first "point" coordinates.
> On X86:
> x=: -53.1275 y= -31.8682
> On ARM:
> x=: -1.00226e-13 y= -1.76938e+52
> Looking for the problem here, i found a thread from Etienne Dube on
> (2004-04-07 05:12:55 GMT), saying it's a byte ordering problem.
> "Each 32-bit word in the 64-bit double value is stored little-endian,
> but the most significative 32-bit word comes last in memory
> ("big-wordian")."
> Changing the word-order for the first feature inside the ".shp" ("11
> 36 3c bd 52 90 4a c0" to "52 90 4a c0 11 36 3c bd") and running it again:
> under X86:
> x=: -1.00226e-13 y= -31.8682
> under ARM
> x=: -53.1275 y= -1.76938e+52
> So, clearly, i have the same problem then Etienne. He sent a patch,
> but didn't made many tests...
> Is there a "final"solution for the problem? I couldn't see any answer
> to him.
> Regards,
> Adriano
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
