[gdal-dev] Re: Conflicts when using GDAL with minGW
LF lucafasano at interfree.it
Tue Feb 24 05:25:13 EST 2009
LF <lucafasano <at> interfree.it> writes:
> > It seems that the GDAL library is causing some functions in the minGW
> > C++ library (cstdio) to be undeclared.
> I had two conflicts between mingw and gdal for variables *_copysign*
> and *ssize_t*, defined in both mingw and gdal.
> Should I define some macros or other else when I want to compile GDAL
> with MinGW?
As you can see I use HDF5 library. Could it cause my problem??
