[gdal-dev] Re: gdal_retile.py -r mode ?
Fri Feb 27 13:33:20 EST 2009
Christian Müller wrote:
> The utility uses the python method gdal.ReprojectImage(....).
> As far as I see in http://www.gdal.org/gdalwarper_8h.html there is a new
> Constant GRA_Lanczos for an interpolation method which is not supported
> at the moment, but I see no constant for "mode" resampling.
> Perhaps we get a hint from an specialist.
> At the moment I see no possibility (but I could be wrong)
Christian,
I do not believe that mode resampling is available via the warp api,
nor is it particularly conducive to such a resampling kernel since it
does not keep close track of which input pixels map to a particular
output pixel.  This is a surprisingly difficult thing to do when an
arbitrary spatial transformation is being applied.
Best regards,
