[gdal-dev] different results for vector and raster data reprojections
nimalika fernando nimalikaf at gmail.com
Fri Feb 27 14:42:39 EST 2009
I have used ogr2ogr to assign projection information(SL99) to some vector
data which does not contain any projection information.
I used the same projection information to reproject a raster in UTM 44N to
SL99.Both data sets contain data of same location.
When I try to overlay the projected data  ( using QGIS where the SL99 is
defined using the same projection information) there is a small shift in two
layers.
When check the projection information using ogrinfo/gdalinfo I found that
even though the same parameters are used for projection of vector and raster
data , some parts of the WKT is different. I am not sure whether this is the
reason for the problem in overlapping.
The resulting WKT are as follows
Raster
PROJCS["Transverse_Mercator",
    GEOGCS["Everest 1830",
        DATUM["unknown",
            SPHEROID["unnamed",6377276.345,300.8017000000115]],
        PRIMEM["Greenwich",0],
        UNIT["degree",0.0174532925199433]],
    PROJECTION["Transverse_Mercator"],
    PARAMETER["latitude_of_origin",7.00047],
    PARAMETER["central_meridian",80.77171],
    PARAMETER["scale_factor",1],
    PARAMETER["false_easting",200000],
    PARAMETER["false_northing",200000],
    UNIT["metre",1,
        AUTHORITY["EPSG","9001"]]]
Vector
        DATUM["unknown",
            SPHEROID["evrst30",6377276.345,300.8017]],
        UNIT["Degree",0.017453292519943295]],
    UNIT["Meter",1]]
Can anybody help me to identify what went wrong  ?
Thanking you
nimalika
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090228/00441567/attachment.html
