[gdal-dev] Re: Failure to compile 1.6.0 with errors 'libgdal.so: undefined reference to `PMPI::Intracomm::current_op'
Francesco P. Lovergine frankie at debian.org
Sat Feb 28 13:51:14 EST 2009
On Fri, Feb 27, 2009 at 02:17:48PM -0000, Steve Walker wrote:
> I was able to complete a successful build by including the following in my
> configure command:
> --with-hdf4=no --with-hdf5=no
> Which then of course leads to the follow-up:  What's wrong with my hdf
> installs?
> I have the following packages installed:
> hdf4-tools
> hdf5-tools
> libhdf4g
> libhdf4g-dev
> libhdf5-lam-1.6.6-0
> libhdf5-openmpi-1.6.6-0
> libhdf5-openmpi-dev
> I am not yet sure if or how this will affect my ability to work with ogdi
> layers.
You should install the serial edition of the hdf5 development stuff before
compiling:
libhdf5-serial-dev
The hdf4 stuff is not relevant.
