[gdal-dev] GDAL autotest (nitf_37) causes a crash on Windows
Tamas Szekeres szekerest at gmail.com
Sat Feb 28 14:09:12 EST 2009
I've been running against the stable branch. Is this an issue?
Best regards,
Tamas
2009/2/28 Even Rouault <even.rouault at mines-paris.org>
> Yes, exactly you need latest trunk to run this test.
> Le Saturday 28 February 2009 18:53:30 Frank Warmerdam, vous avez écrit :
> > I was seeing a somewhat similar effect with the latest nitf.py and
> > a week old FWTools build but when I refreshed from the latest
> > GDAL source the problem went away leading me to suspect that the
> > test is for a recent fix put in by Even.  Are you confident you are
> > running the test with the latest source?  Perhaps there was a short
> > overlap?
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090228/672e5b23/attachment.html
