[gdal-dev] Error (Not enough data for scanline) by using gdaladdo with geotiff
Gregor Fikoczek gregor.fikoczek at wheregroup.com
Fri Jan 9 09:51:50 EST 2009
i am using 'GDAL 1.6.0, released 2008/12/04' on (K)Ubuntu 'Linux
2.6.22-16-generic i686 GNU/Linux'. By using gdaladdo with a geotiff i get the
following Result/Error:
gdaladdo -r nearest test.tif 2 4 8 16
Warning 1: TIFFReadDirectory:test.tif: Wrong "StripByteCounts" field, ignoring
and calculating from imagelength
0Warning 1: TIFFReadDirectory:test.tif: Wrong "StripByteCounts" field,
ignoring and calculating from imagelength
ERROR 1: /home/fikoczek/projekte/bentheim/testbild/8015.9B.tif:DumpModeDecode:
Not enough data for scanline 0
ERROR 1: TIFFReadEncodedTile() failed.
ERROR 1: IReadBlock failed at X offset 0, Y offset 0
ERROR 1: GetBlockRef failed at X block offset 0, Y block offset 0
...10...20...30...40...50...60...70...80...90...100 - done.
Overview building failed.
Anybody an idea ?????
Something with the libtiff ???
Best Regards,
Greg
Some Information (Tiff-Image 300MB):
gdalinfo /home/fikoczek/projekte/bentheim/testbild/orginal/8015.9B.tif
Driver: GTiff/GeoTIFF
Files: /home/fikoczek/projekte/bentheim/testbild/orginal/8015.9B.tif
Size is 10000, 10000
Coordinate System is `'
Origin = (2580500.000000000000000,5816000.000000000000000)
Pixel Size = (0.050000000000000,-0.050000000000000)
Metadata:
  TIFFTAG_SOFTWARE=Adobe Photoshop 7.0
  TIFFTAG_DATETIME=2007:07:10 14:38:18
  TIFFTAG_XRESOLUTION=508
  TIFFTAG_YRESOLUTION=508
  TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
Image Structure Metadata:
  INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left  ( 2580500.000, 5816000.000)
Lower Left  ( 2580500.000, 5815500.000)
Upper Right ( 2581000.000, 5816000.000)
Lower Right ( 2581000.000, 5815500.000)
Center      ( 2580750.000, 5815750.000)
Band 1 Block=10000x1 Type=Byte, ColorInterp=Red
Band 2 Block=10000x1 Type=Byte, ColorInterp=Green
Band 3 Block=10000x1 Type=Byte, ColorInterp=Blue
Some Information (GDAL 1.6.0)./configure --with-xerces
[sudo] password for fikoczek:
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking target system type... i686-pc-linux-gnu
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking C_WFLAGS for maximum warnings... -Wall -Wdeclaration-after-statement
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking CXX_WFLAGS for maximum warnings... -Wall
checking for gcc... (cached) gcc
checking whether we are using the GNU C compiler... (cached) yes
checking whether gcc accepts -g... (cached) yes
checking for gcc option to accept ISO C89... (cached) none needed
checking whether we are using the GNU C++ compiler... (cached) yes
checking whether g++ accepts -g... (cached) yes
checking for a sed that does not truncate output... /bin/sed
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for fgrep... /bin/grep -F
checking for ld used by gcc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm -B
checking the name lister (/usr/bin/nm -B) interface... BSD nm
checking whether ln -s works... yes
checking the maximum length of command line arguments... 32768
checking whether the shell understands some XSI constructs... yes
checking whether the shell understands "+="... yes
checking for /usr/bin/ld option to reload object files... -r
checking how to recognize dependent libraries... pass_all
checking for ar... ar
checking for strip... strip
checking for ranlib... ranlib
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking how to run the C preprocessor... gcc -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for dlfcn.h... yes
checking how to run the C++ preprocessor... g++ -E
checking for objdir... .libs
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC -DPIC
checking if gcc PIC flag -fPIC -DPIC works... yes
checking if gcc static flag -static works... yes
checking if gcc supports -c -o file.o... yes
checking if gcc supports -c -o file.o... (cached) yes
checking whether the gcc linker (/usr/bin/ld) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... yes
checking for ld used by g++... /usr/bin/ld
checking whether the g++ linker (/usr/bin/ld) supports shared libraries... yes
checking for g++ option to produce PIC... -fPIC -DPIC
checking if g++ PIC flag -fPIC -DPIC works... yes
checking if g++ static flag -static works... yes
checking if g++ supports -c -o file.o... yes
checking if g++ supports -c -o file.o... (cached) yes
checking for dlopen in -ldl... yes
checking for nanosleep in -lrt... yes
checking for sin in -lm... yes
checking for ANSI C header files... (cached) yes
checking assert.h usability... yes
checking assert.h presence... yes
checking for assert.h... yes
checking fcntl.h usability... yes
checking fcntl.h presence... yes
checking for fcntl.h... yes
checking for unistd.h... (cached) yes
checking dbmalloc.h usability... no
checking dbmalloc.h presence... no
checking for dbmalloc.h... no
checking for dlfcn.h... (cached) yes
checking for stdint.h... (cached) yes
checking limits.h usability... yes
checking limits.h presence... yes
checking for limits.h... yes
checking locale.h usability... yes
checking locale.h presence... yes
checking for locale.h... yes
checking values.h usability... yes
checking values.h presence... yes
checking for values.h... yes
checking float.h usability... yes
checking float.h presence... yes
checking for float.h... yes
checking errno.h usability... yes
checking errno.h presence... yes
checking for errno.h... yes
checking direct.h usability... no
checking direct.h presence... no
checking for direct.h... no
checking whether byte ordering is bigendian... no
checking for 64bit integer type... long long
checking for 64bit file io... yes
checking for stat64... yes
checking for fopen64... yes
checking for int... yes
checking size of int... 4
checking for long... yes
checking size of long... 4
checking for unsigned long... yes
checking size of unsigned long... 4
checking for void*... yes
checking size of void*... 4
checking for int8... no
checking for int16... no
checking for int32... no
checking native cpu bit order... lsb2msb
checking for vprintf... yes
checking for _doprnt... no
checking for snprintf... yes
checking for vsnprintf... yes
checking for atoll... yes
checking for strtof... yes
checking for getcwd... yes
checking whether strtof is declared... no
checking for gmtime_r... yes
checking for localtime_r... yes
checking for setlocale... yes
checking to enable debug build... no, CFLAGS="-g -O2"
checking whether we should hide internal symbols... no
checking for local include/lib path... none
configure: checking whether we should include thread/mutex support......
        thread safe support disabled.
checking for deflateInit_ in -lz... yes
checking for inflateCopy in -lz... yes
using pre-installed libz
checking for pg_config... /usr/bin/pg_config
checking for PostgreSQL... yes
checking for PQconnectdb in -lpq... yes
checking for PQputCopyData in -lpq... yes
checking for PQescapeStringConn in -lpq... yes
checking for G_gisinit_2 in -lgrass5... no
checking for ffopen in -lcfitsio... no
libcfitsio not found - FITS support disabled
checking for Mopen in -lcsf... no
checking csf.h usability... no
checking csf.h presence... no
checking for csf.h... no
using internal csf code.
checking for nc_open in -lnetcdf... yes
using pre-installed libnetcdf.
checking for png_set_IHDR in -lpng... yes
checking png.h usability... yes
checking png.h presence... yes
checking for png.h... yes
using pre-installed libpng.
checking for TIFFGetTagListCount in -ltiff... yes
checking for _TIFFsetDoubleArray in -ltiff... yes
checking for TIFFScanlineSize64 in -ltiff... no
using pre-installed libtiff.
checking for XTIFFClientOpen in -lgeotiff... no
using internal GeoTIFF code.
checking for jpeg_read_scanlines in -ljpeg... yes
checking jpeglib.h usability... yes
checking jpeglib.h presence... yes
checking for jpeglib.h... yes
using pre-installed libjpeg.
checking for DGifOpenFileName in -lgif... yes
using pre-installed libgif.
checking for cln_GetLayerCapabilities in -logdi31... no
checking for FMEObjects... no
checking for SDreaddata in -lmfhdf... yes
checking for H5Fopen in -lhdf5... yes
checking for jpc_decode in -ljasper... yes
checking for jp2_decode in -ljasper... yes
checking for pgx_decode in -ljasper... yes
checking for jp2_encode_uuid in -ljasper... no
configure: hacked JasPer version not found, GeoJP2 disabled.
checking for NCScbmOpenFileView in -lNCSEcw... no
checking for NCScbmOpenFileView in -lecwj2... no
checking for Kakadu JPEG2000 support... not requested.
configure: MrSID support disabled.
checking for MSG... not requested
checking for BSB... enabled
checking for Oracle OCI headers
in /usr/lib/oracle/xe/app/oracle/product/10.2.0/server/rdbms/public... yes
checking for Oracle OCI libraries
in /usr/lib/oracle/xe/app/oracle/product/10.2.0/server/lib... not found
checking if Oracle support is enabled... no
checking for GRIB... enabled
checking for OGR ... enabled
checking for MySQL... no
checking for Ingres... no
checking for Xerces C++ Parser headers in /usr/include
and /usr/include/xercesc... found
checking for Xerces C++ Parser libraries... found
checking for Xerces C++ Parser... yes
checking if Xerces C++ Parser version is >= 2.7.0... yes
checking for Expat XML Parser headers in /usr/include... found
checking for Expat XML Parser libraries... found
checking for Expat XML Parser... yes
checking if Expat XML Parser version is >= 1.95.0... yes
checking for SQLConnect in -lodbc... yes
checking for SQLInstallDriverEx in -lodbcinst... yes
checking Checking for DODS... disabled
checking for curl-config... /usr/bin/curl-config
        found libcurl version 7.16.4
checking for SQLite3 library >= 3.0.0... yes
checking Checking for DWGdirect... disabled
configure: IBM Informix DataBlade not supported.
configure: checking whether we should include ESRI SDE support...
        ESRI SDE support not requested.
checking for geos-config... /usr/bin/geos-config
checking for GEOS version >= 2.2.0... yes
checking for GEOSversion in -lgeos_c... yes
configure: Using C API from GEOS 2.2.3
checking whether to enable PAM... yes
checking how to link PROJ.4 library... link dynamically.
checking GDAL version information from gdal_version.h: 1.6.0
checking for perl bindings... disabled
checking for php bindings... disabled
checking for ruby bindings... disabled
checking for python bindings... disabled
checking for old-gen python bindings... disabled
configure: creating ./config.status
config.status: creating GDALmake.opt
config.status: WARNING:  GDALmake.opt.in seems to ignore the --datarootdir
setting
config.status: creating port/cpl_config.h
config.status: port/cpl_config.h is unchanged
config.status: executing libtool commands
GDAL is now configured for i686-pc-linux-gnu
  Installation directory:    /usr/local
  C compiler:                gcc -g -O2
  C++ compiler:              g++ -g -O2
  LIBTOOL support:           yes
  LIBZ support:              external
  GRASS support:             no
  CFITSIO support:           no
  PCRaster support:          internal
  NetCDF support:            yes
  LIBPNG support:            external
  LIBTIFF support:           external (BigTIFF=no)
  LIBGEOTIFF support:        internal
  LIBJPEG support:           external
  LIBGIF support:            external
  OGDI support:              no
  HDF4 support:              yes
  HDF5 support:              yes
  Kakadu support:            no
  JasPer support:            yes (GeoJP2=no)
  ECW support:               no
  MrSID support:             no
  MSG support:               no
  GRIB support:              yes
  cURL support (wms/wcs/...):yes
  PostgreSQL support:        yes
  MySQL support:             no
  Ingres support:            no
  Xerces-C support:          yes
  NAS support:               yes
  Expat support:             yes
  ODBC support:              yes
  PGeo support:              yes
  OCI support:               no
  GEORASTER support:         no
  SDE support:               no
  DODS support:              no
  SQLite support:            yes
  DWGdirect support          no
  INFORMIX DataBlade support:no
  GEOS support:              yes
  Old-gen python          no
  SWIG Bindings:          no
  Statically link PROJ.4:    no
  enable OGR building:       yes
  enable pthread support:    no
  hide internal symbols:     no
Mit freundlichen Grüßen
Gregor Fikoczek
WhereGroup GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Gregor Fikoczek
Email: gregor.fikoczek at wheregroup.com
Fon: +49 (0)228 / 90 90 38 - 25
Fax: +49 (0)228 / 90 90 38 - 11
info at wheregroup.com
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
