[gdal-dev] ogrinfo and ogr2ogr are unable to open AVCE00 files
godofredo contreras frdcn at hotmail.com
Mon Jan 12 15:04:54 EST 2009
> godofredo contreras wrote:> > Hi:> > > > I´m trying to open e00 files using ogr but it fails with the> > message "unable to open datasource file.e00 with the following> > drivers" and the list of driver in ogrinfo --formats show> > AVCE00 driver.> > > > I`m using the ogr files bundled with fwtools, the version of> > ogrinfo --version shows GDAL 1.6.0.> > > > Is this a bug in ogr? or it can`t open e00 files?> > Godofredo,> > Can you provide a pointer to the file? OGR can read some E00 files,> but cannot read raster e00 files. There may be other particular e00> type files that are also unreadable.>
Hi Frank,
I downloaded the e00 files from this url http://www.mass.gov/mgis/ftpgnm.htm
I also made a test translating the file to binary and ogr tools works correctly
with the binary version of the file.
Regards Godofredo Contreras
_________________________________________________________________
Windows Live™: Keep your life in sync.
http://windowslive.com/howitworks?ocid=TXT_TAGLM_WL_t1_allup_howitworks_012009
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090112/785e6114/attachment.html
