[gdal-dev] reproject points using raster info
Mon Jan 12 23:33:01 EST 2009
Yann Chemin wrote:
> Hello,
> (C API)
> The aim is to get a (lat,long) pair
> into (projX,projY) pair from hDataset1 projection info.
> Lat/long projection was defined with:
> char    *pszProj4 = "+proj=ll +ellps=wgs84 +datum=wgs84";
Yann,
For a geographic (long/lat) coordinate system you should be
using +proj=longlat, not +proj=ll.
> OGRSpatialReferenceH hSRS;
> OSRImportFromProj4(hSRS, pszProj4);
> printf( "%s\n", pszProj4 );
The Import call looks fine.
> Using GDALGetProjectionRef( hDataset1 ),
> the raster projection info is extracted.
> Here somehow the extracted projection information
> should be imported into a second OGRSpatialReferenceH,
> called hSRS1 for example. But I don't know how to do that.
> I am confused by the C++ examples actually,
> and have difficulties to find a proper C example somewhere to do that.
> thanks for any help/suggestion,
> Yann
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
You might find the code from gdalinfo.c which does roughly the opposite
(projected dataset corners to lat/long) helpful.  Some key parts are:
/*      Setup projected to lat/long transform if appropriate.           */
     if( GDALGetGeoTransform( hDataset, adfGeoTransform ) == CE_None )
         pszProjection = GDALGetProjectionRef(hDataset);
     if( pszProjection != NULL && strlen(pszProjection) > 0 )
         OGRSpatialReferenceH hProj, hLatLong = NULL;
         hProj = OSRNewSpatialReference( pszProjection );
         if( hProj != NULL )
             hLatLong = OSRCloneGeogCS( hProj );
         if( hLatLong != NULL )
             CPLPushErrorHandler( CPLQuietErrorHandler );
             hTransform = OCTNewCoordinateTransformation( hProj, hLatLong );
             CPLPopErrorHandler();
             OSRDestroySpatialReference( hLatLong );
         if( hProj != NULL )
             OSRDestroySpatialReference( hProj );
/*                        GDALInfoReportCorner()                        */
static int
GDALInfoReportCorner( GDALDatasetH hDataset,
                       OGRCoordinateTransformationH hTransform,
                       const char * corner_name,
                       double x, double y )
     double	dfGeoX, dfGeoY;
     double	adfGeoTransform[6];
     printf( "%-11s ", corner_name );
/*      Transform the point into georeferenced coordinates.             */
         dfGeoX = adfGeoTransform[0] + adfGeoTransform[1] * x
             + adfGeoTransform[2] * y;
         dfGeoY = adfGeoTransform[3] + adfGeoTransform[4] * x
             + adfGeoTransform[5] * y;
     else
         printf( "(%7.1f,%7.1f)\n", x, y );
         return FALSE;
/*      Report the georeferenced coordinates.                           */
     if( ABS(dfGeoX) < 181 && ABS(dfGeoY) < 91 )
         printf( "(%12.7f,%12.7f) ", dfGeoX, dfGeoY );
     else
         printf( "(%12.3f,%12.3f) ", dfGeoX, dfGeoY );
/*      Transform to latlong and report.                                */
     if( hTransform != NULL
         && OCTTransform(hTransform,1,&dfGeoX,&dfGeoY,NULL) )
         printf( "(%s,", GDALDecToDMS( dfGeoX, "Long", 2 ) );
         printf( "%s)", GDALDecToDMS( dfGeoY, "Lat", 2 ) );
     printf( "\n" );
     return TRUE;
