[gdal-dev] Write 8-bit image...
Christopher Barker Chris.Barker at noaa.gov
Tue Jan 13 15:33:28 EST 2009
Tripp Lowe wrote:
> I see in the docs that /"GDAL
> <http://map.hut.fi/doc/Geo-GDAL/html/class_geo_1_1_g_d_a_l.html> raster
> data types are Byte UInt16 Int16 UInt32 Int32 Float32 Float64 CInt16
> CInt32 CFloat32 CFloat64"/.
> How do I specify an 8-bit data type?
That would be "Byte" on any machine you're likely to encounter.
-Chris
Christopher Barker, Ph.D.
Oceanographer
Emergency Response Division
NOAA/NOS/OR&R            (206) 526-6959   voice
7600 Sand Point Way NE   (206) 526-6329   fax
Seattle, WA  98115       (206) 526-6317   main reception
