[gdal-dev] improve PDS and Isis drivers
Wed Jan 14 12:55:26 EST 2009
lidiriel wrote:
> hi,
> I work with several pds files and i have many idea for improve
> driver :
> Add several domaine (for obtain a classification) with standard
> Metadata like describe in "PDS standars reference" document (chapter5
> v3.7) each domain can contains a minimum number of keys.
> domaine name (dn): LABEL_STANDARDS
> keys : PDS_VERSION_ID, DD_VERSION_ID, LABEL_REVISION_NOTE
> dn : FILE_CHARACTERISTICS
> keys: RECORD_TYPE, RECORD_BYTES, ...
> dn : IDENTIFICATION_DATA_ELEMENTS
> keys: DATA_SET_ID ...
> implementation of reading a detached data in first time for ISIS2
> driver :
> ("filename", nnn) (chapter 5 page 13 of PDS specification v3.7)
> Many of my data use this last notation and for using gdal i will must
> implemented this in priority.
Lidiriel,
I am reasonably supportive of adding capture and exposure of metadata
from PDS, ISIS2 and ISIS3 datasets in some appropriate fashion. I'd
be open to appropriate patches though I'm not inclined to do much more
directly as implementation than I have already done, unless my original
client (USGS) demonstrated an interest.
I believe we do have some support for detached datasets.  Perhaps that
is only in ISIS3?  I would be happy to have detached support also added
in ISIS2.
Best regards,
