[gdal-dev] How to use TransformPoints in python?
Fri Jan 16 09:07:37 EST 2009
Hogendoorn, Rene wrote:
>     x = numpy.array( [p[0] for p in polygon] )
>     y = numpy.array( [p[1] for p in polygon] )
>     z = numpy.array( [p[2] for p in polygon] )
>     print proj.TransformPoints( len(polygon), x, y, z)
> returns:
> Traceback (most recent call last):
>   File "<stdin>", line 37, in <module>
>   File
> "/var/tmp/libgdal0-1.6.0-build/usr/lib64/python2.6/site-packages/osgeo/osr.py",
> line 622, in TransformPoints
> TypeError: in method 'CoordinateTransformation_TransformPoints',
> argument 3 of type 'double *'
> I also tried straight python lists of doubles.
> So what type of arguments does TransformPoints expect (as there is
> obviously nothing like double* in python)?
Rene,
To the best of my knowledge TransformPoints() is not currently working smoothly
with Python.  I have just been using TransformPoint().  You might want to file
a ticket on this.
Best regards,
