[gdal-dev] OGR error
Fri Jan 16 09:41:05 EST 2009
nicholas.g.lawrence at mainroads.qld.gov.au wrote:
> I am using ogr2ogr to append several shapefiles into one shapefile.
> The command
> ogr2ogr -update -append C:\DATA\neville\fire.shp
> C:\DATA\neville\bundaberg.shp -nln fire
> which is repeated many times in a batch file to append more and more
> shapefiles to
> the destination file.
> After about a dozen successful appends, I get this error message
> ERROR 1: Error in psSHP->sHooks.FSeek() or fwrite() writing object to .shp
> file.
> which is repeated a 1000 times until ogr2ogr decides to stop giving
> warnings.
Nick,
It basically means that writes to the .shp file are failing.  The most
likely reason is that your disk is full or the .shp file grew to be
larger than 2GB/4GB.  Are either of those possible?  If not, we would
need to pursue normal bug reporting approaches.
Best regards,
