[gdal-dev] Intersect of two shapefiles
Fri Jan 16 09:44:11 EST 2009
nicholas.g.lawrence at mainroads.qld.gov.au wrote:
> I have two shapefiles containing polygons.
> Can OGR derive an intersection of these two layers?
Nick,
The OGR commandline tools do not include anything to do this.  You could
do it using the library or write a script in one of the supporting bindings
languages.  The key method is OGRGeometry::Intersection() which when invoked
on one geometry with another geometry will return a new geometry which is
their intersection.
http://www.gdal.org/ogr/classOGRGeometry.html#202ad4c29487ca046c4a2b055042cb6a
Note that this method depends on GDAL/OGR having been built against the GEOS
geometry library which really does the work.
Best regards,
