[gdal-dev] using GDAL in a java-program
Even Rouault even.rouault at mines-paris.org
Sat Jan 17 14:11:47 EST 2009
Le Friday 16 January 2009 18:14:00 Frank Warmerdam, vous avez écrit :
> I'm not exactly sure how to make the callback work for reporting progress.
> Hopefully you can just pass null for that.  There are a couple very brief
> examples of Java use in gdal/swig/java/apps though they don't cover
> building overviews.
I should mention that I'm currently working on improving the Java bindings.
In fact, the BuildOverviews() is one of the methods whose signature has
changed in trunk.
Previously (1.5.X and 1.6.0), the signature was :
  public int BuildOverviews(String resampling, int[] overviewlist,
                                         SWIGTYPE_p_GDALProgressFunc callback,
                                         java.nio.ByteBuffer callback_data)
which was obviously wrong (wrong and missing typemaps for the callback).
In trunk, we now have :
                                          ProgressCallback callback);
where callback :
- can be passed as null,
- or used like this for the standard GDAL progress on the terminal:
	BuildOverviews(resampling, overviewlist, new TermProgressCallback());
- or for a custom progress method:
                        new ProgressCallback()  {
                           public int run(double dfProgress, String message) {
                              System.out.println(message + " " +
                                                      100 * dfProgress + "%");
                                return 1;
And (not commited yet), the callback argument will be an optional argument.
Do people think that these changes (only made when previous typemaps were
wrong or missing) will be too disruptive ? If so, we could imagine adding
compatibilty methods, to keep the same number of arguments. For example:
                                         Object unused1, Object unused2)
     return BuildOverviews(resampling, overviewlist, null);
but even if the number of argument is the same, the binary signature of the
method would be different and people would have to recompile their Java code
to run against the new GDAL .jar file. In any event, if people really need
such a compatibilty layer, we'd need to know which methods they are using.
I should also mention that the API for many methods (like
Dataset.ReadRaster(), Dataset.WriteRaster(), Dataset.SetGCP(), anything
related to ColorTable) was so broken that they probably could not be used.
Any thought ?
Even
