[gdal-dev] OTB 2.8 available
jordi inglada jordi.inglada at cnes.fr
Sun Jan 18 11:34:48 EST 2009
 Dear all,
CNES is happy to announce the release of OTB 2.8, code name "¹§Ï²·¢²Æ" (Gong Xi
Fa Cai).
The main additions to this version are both on the library and the
applications.
End users will be happy to find 3 very useful new applications:
1. Object Counting <
http://blog.orfeo-toolbox.org/uncategorized/counting-objects>
2. Fine Registration <
http://blog.orfeo-toolbox.org/uncategorized/fine-registration>
3. Road Extraction <
http://blog.orfeo-toolbox.org/preview/road-extraction-revamped>
A very user-friendly installer for the whole set of applications is provided
for Windows users.
Library users will be interested about:
1. A new implementation (faster, more robust) of the SIFT algorithm
2. The Speed-Up Robust Features (SURF) kindly contributed by
Communications & Syst¨¨mes
3. The Mean Shift filtering and clustering algorithm
4. The out-of-the-box support for KML and OpenStreetMaps
5. The support for lidar data using libLAS <http://liblas.org/>
As usual, you can go to <http://www.orfeo-toolbox.org/> and follow the
download link or get directly to Sourceforge
<http://sourceforge.net/projects/orfeo-toolbox/> and get the packages
there. Full source code, Software Guide and Windows binaries are
available.
OTB is the only open source library which makes available a full set of
building blocks for implementing remote sensing image processing going
from low level to advanced map applications. All this thanks to, among
others,
ITK, GDAL and OSSIM.
>From sensor models to GoogleEarth format compatibility, from image
filtering to Support Vector Machine classification and regression, from
binary mathematical morphology to SIFT matching, from rigid registration
to PDE-based disparity map estimation, and much more.
Subscribe to <http://blog.orfeo-toolbox.org/feed> if you want to get
periodic updates about OTB.
Best regards,
J. Inglada
CNES - DCT/SI/AP - BPI 1219
18, avenue Edouard Belin
31401 Toulouse Cedex 09 - France
Tel. +33.(0)5.61.27.33.97 - Fax. +33.(0)5.61.28.31.09
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090118/25c6e1ac/attachment.html
