[gdal-dev] How to use TransformPoints in python?
Christopher Barker Chris.Barker at noaa.gov
Tue Jan 20 15:04:55 EST 2009
This doesn't address the issue, but:
>>     x = numpy.array( [p[0] for p in polygon] )
>>     y = numpy.array( [p[1] for p in polygon] )
>>     z = numpy.array( [p[2] for p in polygon] )
these list comprehensions are unnecessary -- numpy understands nested lists:
poly_array = numpy.array(polygon)
x = poly_array[:,0]
y = poly_array[:,1]
z = poly_array[:,2]
It would be nice if the gdal bindings understood NX3 numpy arrays
directly. If the C code can accept a C NX3 *double, then the numpy.i
swig interface files that come with numpy would make it easy to do. Some
day!
-Chris
Christopher Barker, Ph.D.
Oceanographer
Emergency Response Division
NOAA/NOS/OR&R            (206) 526-6959   voice
7600 Sand Point Way NE   (206) 526-6329   fax
Seattle, WA  98115       (206) 526-6317   main reception
