[Gdal-dev] Creating Lambert Azimutal projection
jumpjack jumpjack at libero.it
Sun Jan 25 09:49:02 EST 2009
I'd need to convert some images into Lambert Azimuthal projection:
http://www.evl.uic.edu/pape/data/Earth/
What I want to obtain is something like this:
http://astrogeology.usgs.gov/Gallery/MapsAndGlobes/mars.html#MarsViking
I have been told this the procedure I have to use:
"Create a series of 12 Transverse Mercator projections that are 32 degrees
in longitude and 91 degrees in latitude to form a "flower petal" projection
for making globes. If the northern hemisphere is being created, the latitude
range is -1 to +90. If the southern hemisphere is being created, the
latitude range is -90 to 1. The petals are formed by changing the center
longitude and map rotation in steps of 30 degrees for each Transverse
Mercator projection. Each section is put into the mosaic. The final center
of the projection is a Lambert Azimuthal Equal-area centered on the pole and
covers from -90 to -75 or 75 to 90 degrees latitude and 360 degrees in
longitude. This is the last cube that is placed in the mosaic."
Can I accomplish this with GDALWARP?
Which commandline should I use?
View this message in context: http://n2.nabble.com/Creating-Lambert-Azimutal-projection-tp2213261p2213261.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
