[gdal-dev] Can I create a GDAL data set from bytes in memory?
Wed Jan 28 11:36:13 EST 2009
Joel Odom wrote:
> I've got a situation where I'm trying to use GDAL to read image files
> contained within a KMZ archive.  (My project uses both GDAL and libkml.)
>  Libkml can easily read the image file into memory out of the KMZ
> archive, but I'd like to pass it to GDAL without having to write it to a
> temporary file on disk.  I haven't figured out if this can be done yet.
>  Thanks for any answers.
Joel,
Yes, from C/C++ you can generally utilize the VSI*L facilities to wrap
a memory buffer and have it treated by GDAL as a file.  It does not work
for every image driver, but it works for most common ones.  The documentation
is available with the VSIInstallMemFileHandler() function:
   http://www.gdal.org/cpl__vsi_8h.html#66e2e6f093fd42f8a941b962d4c8a19e
Best regards,
