Re: [gdal-dev] GDAL in Netbeans IDE
Lucena, Ivan ivan.lucena at pmldnet.com
Sat Jan 31 18:28:35 EST 2009
Mateusz.
I don't mind at all. That is great.
Ivan
>  -------Original Message-------
>  From: Mateusz Loskot <mateusz at loskot.net>
>  Subject: Re: [gdal-dev] GDAL in Netbeans IDE
>  Sent: Jan 31 '09 19:17
>  Iva,
>  I've taken the liberty to post your notes on the Wiki:
>  http://trac.osgeo.org/gdal/wiki/BuildingOnUnixWithNetBeansIDE
>  I hope you don't mind.
>  Best regards,
>  Mateusz
>  Ivan Lucena wrote:
>  > Hi Vali,
>  > On NetBeans 6.5 you select:
>  > Main Form:
>  >     File/New Project
>  > New Project wizard dialog:
>  >     1. Choose Project
>  >        Category: C/C++
>  >        Projects: C/C++ Project From Existing Code
>  >        Click on "Next>"
>  >     2. Build Tool:
>  >        Select "Using existing makefile"
>  >        Browse or type the full path for the main GNUmakefile
>  >        or:
>  >        Select "Using a makefile generate by a 'configure' script
>  >        Note: I never used that options since I already run ./configure
>  >              from the command line but that could a a good way to go too.
>  >     3. Build actions:
>  >        Working Directory: <main GDAL folder path>
>  >        Build command: make
>  >        Clean command: make clean
>  >     4. Source files:
>  >        Click on "Add Folder: <main GDAL folder path>
>  >     5. Code assistance configuration:
>  >        Select "Automatic configuration"
>  >     6. Project Name and location
>  >        Note: Those path doesn't need to be GDAL folder path
>  > That is it.
>  > Best regards,
>  > Ivan
>  > Vali Poncos wrote:
>  >> Hello,
>  >> Does anybody know how to import the GDAL projects in Netbeans IDE 6.1?
>  >> Is there another IDE used to compile GDAL?
>  >> Thanks,
>  >> Vali
>  >> Now with a new friend-happy design! Try the new *Yahoo! Canada
>  >> Messenger* <http://ca.beta.messenger.yahoo.com/>
>  >> _______________________________________________
>  >> gdal-dev mailing list
>  >> gdal-dev at lists.osgeo.org
>  >> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>  Mateusz Loskot
>  http://mateusz.loskot.net
