[gdal-dev] can java use the jdal
Daniele Romagnoli dany.geotools at gmail.com
Tue Jul 7 10:30:51 EDT 2009
you can also take a look on our imageio-ext project which extends Sun's Java
ImageIO framework, also leveraging on gdal.
See here: https://imageio-ext.dev.java.net/
Hope this helps.
Cheers,
Daniele
On Tue, Jul 7, 2009 at 3:25 PM, Frank Warmerdam <warmerdam at pobox.com> wrote:
> maven apache wrote:
>> I wonder if there is a java librariy which can be directly used to handle
>> the data instead of using the Runtime to call the command(for example
>> glalinfo......)?
> Maven,
> The GDAL project includes java bindings for the api so it should be
> practical to recreate pretty much any of the commandline programs
> in Java.  There is already an example for gdalinfo.
>  http://trac.osgeo.org/gdal/wiki/GdalOgrInJava
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam<http://pobox.com/%7Ewarmerdam>
> and watch the world go round - Rush    | Geospatial Programmer for Rent
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Eng. Daniele Romagnoli
Software Engineer
GeoSolutions S.A.S.
Via Carignoni 51
55041 Camaiore (LU)
Italy
phone: +39 0584983027
fax:     +39 0584983027
mob:   +39 328 0559267
http://www.geo-solutions.it
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090707/8b0f6172/attachment.html
