[gdal-dev] Blocksize in VRT files
Ozy Sjahputera sjahputerao at missouri.edu
Wed Jul 8 16:35:56 EDT 2009
I have been using the VRT format a lot lately and loving it!
I created the VRT files in two ways:
1). directly writing the XML file (usually using SimpleSource or
ComplexSource)
2). using GDALAutoCreateWarpedVRT()
I found out that the VRT files created using the first method has
blocksize of 128x128. While VRT files created using
GDALAutoCreateWarpedVRT() has blocksize of 512x128.
Is there a way for the user to specify VRT file blocksize when creating
the file using the two methods above?
Thanks
Ozy
