[Gdal-dev] building GDAL under cygwin with ODBC
Neil Best nbest at ci.uchicago.edu
Wed Jul 8 18:31:12 EDT 2009
Does anyone know if it's possible?
I said:
./configure --with-odbc=/usr/include/w32api
and then make throws a bunch of errors involving .h files in that directory.
If anyone has tried this I would appreciate hearing from you.
Would it be any different undr MinGW?  I have never worked with it so I
don't know what to expect.  I just want to be able to wrap ogr2ogr in a bash
script on a WinXP machine.
Thanks.
Neil
View this message in context: http://n2.nabble.com/building-GDAL-under-cygwin-with-ODBC-tp3228405p3228405.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
