[gdal-dev] gdal NITF complex driver question
Gong, Shawn (Contractor) Shawn.Gong at drdc-rddc.gc.ca
Fri Jul 10 09:54:24 EDT 2009
Thanks Even.
I will try the patch and report back.
Shawn
-----Original Message-----
From: Even Rouault [mailto:even.rouault at mines-paris.org]
Sent: Thursday, July 09, 2009 5:08 PM
To: gdal-dev at lists.osgeo.org
Cc: Gong, Shawn (Contractor)
Subject: Re: [gdal-dev] gdal NITF complex driver question
Shawn,
I'm not surprised. Someone already provided quite the same patch in
http://trac.osgeo.org/gdal/ticket/2526 but I had a doubt about missing
swapping of real and imaginary fields. As I couldn't test not having test
data, this wasn't applied.
Could you also apply the attached patch to nitfimage.c (from trunk) and
confirm if it does correct byte-swapping ? Anyway, attaching test data to the
above ticket would be really great to avoid blind guessing !
Best regards,
Even
Le Thursday 09 July 2009 22:40:11 Gong, Shawn (Contractor), vous avez écrit :
> hi list,
> We made a slight modification in gdal/frmts/nitf/nitfdataset.cpp to add
> support for RADARSAT-2 NITF Single Look Complex format.
> in NITFRasterBand::NITFRasterBand( NITFDataset *poDS, int nBand )
> /*      Translate data type(s).
> added:
>     else if( psImage->nBitsPerSample == 64
>              && EQUAL(psImage->szPVType,"C") )
>         eDataType = GDT_CFloat32;
> However we found that the real and imaginary fields come out switched.
> i.e. the gdal driver put Q in front of I.
> We used OpenEV and gdal_translate to confirm that.
> Any thoughts and help are appreciated.
> thanks,
> Shawn
