[gdal-dev] gdalbuildvrt and nulls again - now from Photoshop
William Kyngesburye woklist at kyngchaos.com
Fri Jul 10 15:14:18 EDT 2009
This time I'm taking some Photoshop-created tiffs that I georeference
with a TFW.  These tiffs I save with transparency mask (not layers) to
handle nulls.
Reported by gdalinfo, they appear as:
Band 1 Block=12775x5 Type=Byte, ColorInterp=Red
   Mask Flags: PER_DATASET ALPHA
Band 2 Block=12775x5 Type=Byte, ColorInterp=Green
Band 3 Block=12775x5 Type=Byte, ColorInterp=Blue
Band 4 Block=12775x5 Type=Byte, ColorInterp=Alpha
But when I run gdalbuildvrt on them, they are skipped:
gdalbuildvrt does not support heterogenous band numbers. Skipping
[sometiff].
If I save it with layers instead of transparency, GDAL doesn't see the
alpha mask on the layer:
Band 1 Block=12775x6 Type=Byte, ColorInterp=Red
Band 2 Block=12775x6 Type=Byte, ColorInterp=Green
Band 3 Block=12775x6 Type=Byte, ColorInterp=Blue
Is there a way I can get gdalbuildvrt to recognize the transparency as
null, without converting them with gdal_translate first?  Maybe a
different way to save the tiff with a mask from Photoshop?
Does the vrt format support a tiff transparency mask as null (and it's
just gdalbuildvrt that doesn't)?
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"History is an illusion caused by the passage of time, and time is an
illusion caused by the passage of history."
- Hitchhiker's Guide to the Galaxy
