[gdal-dev] Question about GDALDataType::GDT_Float32
Fri Jul 10 17:28:36 EDT 2009
Adeel Raza wrote:
> Hi,
> I'm using the GDALRasterBand::RasterIO() function to write a buffer of
> C/C++ float types to a raster band of data type
> GDALDataType::GDT_Float32. I assumed that this conversion would not be
> problem since the size of a C/C++ float is also 32 bits, but I wanted to
> be sure. If the conversion will be problematic, how would I resolve the
> issue (ex: a potential cast maybe).
Adeel,
There is no problem.  The GDT_Float32 enumeration value refers to the
normal 32bit system "float" type in C/C++.
I would add that you should expect, and provide float's in native
machine order.  GDAL will take care of byte swapping during io if
needed.
Best regards,
