[gdal-dev] C# Nad27 to WGS 84
Tomas R monshi at home.se
Sun Jul 12 04:11:01 EDT 2009
Hi again,
New problems arises as the world of Gdal is quite complex to grasp.
Have understood that the transformation of coordinates from Nad 27 datum
to WGS 84 requires some look up tables to be done correctly, tables that
differ with the are the Nad 27 is valid in.
Simple question is, how to set up a general solution in C# that uses
these shift tables.
I have in code a simple test:
           SpatialReference spatNad27 = new SpatialReference("");
            spatNad27.SetWellKnownGeogCS("Nad27");
            SpatialReference spatNad83 = new SpatialReference("");
            spatNad83.SetWellKnownGeogCS("Nad83");
            CoordinateTransformation trans = new
CoordinateTransformation(spatNad27, spatNad83);
            double[] p = new double[3];
            trans.TransformPoint(p, -117, 30, 0);
that gives back
-117, 30,0000000008175
which I believe is not correct ( see http://proj.maptools.org/faq.html )
I have Proj4.dll, I have set an environment path to PROJ_LIB where the
nad shift tables should exist. Must I do something else in the setup or
is the call to the transform different? or have I done correctly but
misinterpreted the results?
What I in reality is interested is transforming whatever coordinate in
whatever projection/datum to and from WGS84 without any extra hassle
fast and easy via the C# interface. That should not be to hard? Or?
Yours
Tomas
