[postgis-devel] [gdal-dev] Question about gdal2wktraster
Jorge Arévalo jorge.arevalo at gmail.com
Tue Jul 14 09:03:00 EDT 2009
Hello,
On Tue, Jul 14, 2009 at 12:14 AM, Mateusz Loskot<mateusz at loskot.net> wrote:
> Pierre Racine wrote:
>> Jorge,
>> 4267 should be the right CS (http://spatialreference.org/ref/epsg/4267/).
> Actually, it isn't.
> What gdalinfo reports for the file cea.tif is a projected CS,
> this one to be precise:
> http://www.remotesensing.org/geotiff/proj_list/cylindrical_equal_area.html
> "There does not seem to be an EPSG equivelent."
> Check this too:
> http://lists.maptools.org/pipermail/geotiff/2005-March/000138.html
> Jorge,
> I'd suggest to test datasets based on EPSG 4326 first.
> After these work for you, then switch to projected ones.
Do you know where can I find geotiff images based on EPSG:4326?
Many thanks in advance
Best Regards
Jorge
