[postgis-devel] [gdal-dev] Question about gdal2wktraster
Mateusz Loskot mateusz at loskot.net
Tue Jul 14 11:21:14 EDT 2009
Jorge Arévalo wrote:
> Hello,
> On Tue, Jul 14, 2009 at 3:28 PM, Mateusz Loskot<mateusz at loskot.net> wrote:
>>>> I'd suggest to test datasets based on EPSG 4326 first.
>>>> After these work for you, then switch to projected ones.
>>> Do you know where can I find geotiff images based on EPSG:4326?
>> Jorge,
>> My favorite images for initial and basic testing of WKT Raster are here:
>> http://download.osgeo.org/gdal/data/gtiff/
>> First, I use utm.tif to test if 1 band raster works.
>> This one is UTM (EPSG:26711) not WGS 84, but it's perfectly usable as such.
>> Also, you can easily transform it to WGS84 with GDAL utils if you like.
> Actually, this is the same image I was using (cea.tif), but mine has
> wrong srid... Thanks a lot for the info!
Yes, I know. utm.tif and cea.tif have the same content
but these datasets are different, not the same because of projection.
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
