[gdal-dev] Is it possible to perform a warp operation on an MEM dataset?
Adeel Raza adeel.raza at crc.gc.ca
Tue Jul 14 13:11:31 EDT 2009
Is it possible to perform a warp operation on an MEM dataset? And if it
is possible should I just follow the guidelines suggested in the Warp
API tutorial on the GDAL website? The reason why I want to do this is
because recently I have discovered that Read/Write operations to an MEM
dataset are much quicker than to a VRT dataset created from
GDALAutoCreatWarpedVRT().
Best Regards,
Adeel Raza.
