[gdal-dev] gdalbuildvrt and nulls again - now from Photoshop
Even Rouault even.rouault at mines-paris.org
Tue Jul 14 14:28:09 EDT 2009
Le Friday 10 July 2009 21:14:18 William Kyngesburye, vous avez écrit :
> This time I'm taking some Photoshop-created tiffs that I georeference
> with a TFW.  These tiffs I save with transparency mask (not layers) to
> handle nulls.
> Reported by gdalinfo, they appear as:
> Band 1 Block=12775x5 Type=Byte, ColorInterp=Red
>    Mask Flags: PER_DATASET ALPHA
> Band 2 Block=12775x5 Type=Byte, ColorInterp=Green
> Band 3 Block=12775x5 Type=Byte, ColorInterp=Blue
> Band 4 Block=12775x5 Type=Byte, ColorInterp=Alpha
> But when I run gdalbuildvrt on them, they are skipped:
> gdalbuildvrt does not support heterogenous band numbers. Skipping
> [sometiff].
This warning means that you are giving a list of datasets that don't have the
same number of bands. For example, if the first dataset examined by
gdalbuildvrt has only 3 bands, it will ignore any further dataset whose band
number is not 3. (if the error message isn't clear, you're welcome to suggest
a better one)
> If I save it with layers instead of transparency, GDAL doesn't see the
> alpha mask on the layer:
> Band 1 Block=12775x6 Type=Byte, ColorInterp=Red
> Band 2 Block=12775x6 Type=Byte, ColorInterp=Green
> Band 3 Block=12775x6 Type=Byte, ColorInterp=Blue
I'm not sure what a 'layer' is for photoshop, but it is something apparently
ignored by GDAL. Would 'tiffdump' show something interesting on those files ?
> Is there a way I can get gdalbuildvrt to recognize the transparency as
> null, without converting them with gdal_translate first?  Maybe a
> different way to save the tiff with a mask from Photoshop?
Just run gdalbuildvrt on a list of datasets that have all 4 bands.
> Does the vrt format support a tiff transparency mask as null (and it's
> just gdalbuildvrt that doesn't)?
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "History is an illusion caused by the passage of time, and time is an
> illusion caused by the passage of history."
> - Hitchhiker's Guide to the Galaxy
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
