[gdal-dev] Failed to process SRS definition
Jørn Vegard Røsnes jorn at spacetec.no
Wed Jul 15 07:12:38 EDT 2009
Hi all,
can you see the problem (this works with proj4)?
It works if I remove "+a=6378273" from proj4-string, but I assume the output
will be wrong.
./ogr2ogr -s_srs EPSG:4326 -t_srs "+proj=stere +lat_0=90 +lon_0=315 +lat_ts=70
+units=m +a=6378273 +e=0.081816153" -f "ESRI Shapefile" gshhs_land_stere
~/download/gshhs_1.3_shapefiles/gshhs_land/
All binaries (proj4, ogr2ogr) from FWTools 2.0.6
cheers
Jørn Vegard
