[gdal-dev] Failed to process SRS definition
Even Rouault even.rouault at mines-paris.org
Thu Jul 16 14:59:55 EDT 2009
Le Thursday 16 July 2009 10:14:27 Jørn Vegard Røsnes, vous avez écrit :
> Hi again,
> On Wednesday 15 July 2009 13:12:38 Jørn Vegard Røsnes wrote:
> > Hi all,
> > can you see the problem (this works with proj4)?
> > It works if I remove "+a=6378273" from proj4-string, but I assume the
> > output will be wrong.
> > ./ogr2ogr -s_srs EPSG:4326 -t_srs "+proj=stere +lat_0=90 +lon_0=315
> > +lat_ts=70 +units=m +a=6378273 +e=0.081816153" -f "ESRI Shapefile"
> > gshhs_land_stere ~/download/gshhs_1.3_shapefiles/gshhs_land/
> I have downloaded v1.6.1, added some debug and compiled (--enable-debug).
> It seems that
> ogr/ogr_srs_proj4.cpp OGRSpatialReference::importFromProj4, line 847 - 945
> does not read the +e proj4 parameter (neither +f and +es), ref. page 9 in
> proj4 doc (ftp://ftp.remotesensing.org/proj/OF90-284.pdf).
> +b and +rf is read by the code, so maybe there is a math. workaround?
Yes, the a,b,e,f and rf parameters are tied by math relations.
See http://www.arsitech.com/mapping/geodetic_datum. (rf is reverse flattening
= inverse flattening)
> cheers
> Jørn Vegard
> > All binaries (proj4, ogr2ogr) from FWTools 2.0.6
> > cheers
> > Jørn Vegard
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
