[gdal-dev] crop an image
Thu Jul 16 16:24:51 EDT 2009
Steve.Toutant at inspq.qc.ca wrote:
> Hello,
> I need to crop an image based on a polygon from a shapefile.
> Could not figure how to do it so I used gdal_translate and I specified
> the extent of the shapefile like this
> gdal_translate -projwin -428734.998712 20337 1.497532 -387578.449250
> 172036.180727 EstMtl.img rssMtl.img
> But the polygon is irregular. So the new image contains the region I
> need with some extra.  From this new image Is there a way to assign
> "nodata" to pixels outside the irregular polygon?
> Or maybe there is a way to crop an image from an irregular polygon?
> thanks
Steve,
You can use the gdal_rasterize command to burn a nodata value to all
pixels outside a target polygon.
eg.
   gdal_rasterize -burn 0 -i -l polygon polygon.shp rssMtl.img
Note the -i flag meets to invert - that is assign all pixels outside
the polygon instead of all the pixels inside the polygon.
Docs at:
   http://www.gdal.org/gdal_rasterize.html
Best regards,
