[gdal-dev] Fwd: [GRASS-user] The geotiff format problem
maven apache apachemaven0 at gmail.com
Thu Jul 16 20:51:46 EDT 2009
---------- Forwarded message ----------
Date: 2009/7/17
Subject: Re: [GRASS-user] The geotiff format problem
To:
Cc: grass-user at lists.osgeo.org
2009/7/17 Markus Neteler <neteler at osgeo.org>
> On Thu, Jul 16, 2009 at 3:10 PM, maven apache<apachemaven0 at gmail.com>
> wrote:
> > Hi all:
> > I have exported the roads in the Spanish example DataBase to a geotiff
> and
> > post it through the wcs.
> > Then I want to handle it :
> > 1)download the tiff in my webservice.
> > 2)use the geotools to parser the tiff,however I got the errors:GeoKey
> > directory does not exist.
> > So I wonder the geotiff from the grass is not identified by the geotools?
> Did you use r.out.gdal? (which GRASS version)?
Yes, I use the r.out.gdal
> If yes, then the GDAL library is responsible since GRASS calls GDAL to
> generate the file. In that case the gdal-dev list may be of better help.
I will call the gdal-user list
Thank you!
> If no, please tell us how you exported.
> Markus
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090717/d125faba/attachment.html
