[gdal-dev] Regarding using OCI
Peter J Halls P.Halls at york.ac.uk
Fri Jul 17 07:19:04 EDT 2009
Srikanth,
Srikanth wrote:
> Peter ,
> To be more specific, I want to store a ESRI shape file into the oracle
> database. I would like to know whether gdal provides such a kind of
> direct method where in if one passes the shape file name it gets
> stored in the database handling the conversion of SDO_GEOM type
> internally.
> I have gone through the example provided by Mr.Frank ( fastload.cpp
> and ocitest.cpp ) but he I do not want handle the oci calls by myself.
> Is there any possibilty to meet my requirement.
All you need is the ogr2ogr utility.  See the example in the driver
documentation which shows how to specify an OCI output.
Peter
> Regards,
> Srikanth
> On Fri, Jul 17, 2009 at 3:20 PM, Peter Halls<P.Halls at york.ac.uk> wrote:
>> Srikanth,
>>  with the driver documentation, Frank has provided a simple overview
>> example. Otherwise, the OCI driver works just like any other. Look carefully
>> at Frank's syntax for the connection string, though.
>>  I've been using this driver for a couple of years now with very good
>> results - indeed, this seems more convenient than using the ArcSDE driver
>> interface and is a good test that the SDE environment is properly set up to
>> share data through Oracle.
>>  I'm not in my office at the moment, however when I'm back I could dig out
>> some examples of how my code uses the OCI driver, if that would be any help
>> to you.
>> Best wishes,
>> Peter
>> On Jul 17 2009, Srikanth wrote:
>>> Dear All,
>>> I want to connect to Oracle and save/retrieve the vector/raster files
>>> using OCI. I have identified the classes ( ogrocidriver, ogrocistatement,
>>> ogrocitablelayer, etc) in GDAL to achieve this.But I did not find any
>>> documentation or examples to guide. I would be thankful if anyone can
>>> provide me suitable examples or guide me in locating suitable documenation.
>> Peter Halls, University of York GIS Advisor
>> Snail Mail: Computing Service, Heslington, York YO10 5DD, England
>> Telephone: 01904 433806   FAX: 01904 433740
>> This message has the status of a private & personal communication
Peter J Halls, GIS Advisor, University of York
Telephone: 01904 433806     Fax: 01904 433740
Snail mail: Computing Service, University of York, Heslington, York YO10 5DD
This message has the status of a private and personal communication
